3FE conversion in a FJ40
Olathe, KS
I am thinking about doing a 3FE conversion in my FJ40. Has anyone done one or know of anyone who has?
I am getting conflicting info on the conversion, I have heard it is a direct replace of a F or 2F and only ECU and wiring hareness need to be changed to the block is two short and there will be fan and exhaust issues.
Any tips, tricks or knowledge of how difficult or easy this would be?
talk to dave at urban land cruisers,,, he might suggest going with a carb on the 3fe,,, can get the parts from SOR,,
tonkota said:
Go over to Pirate and look for Pskaat. He did this about a year or so ago. Lots of fitment problems with the manifolds and the brake MC.
PBB reports "Invalid User specified" when I search for Pskaat in the TLC forum...
A carb on the 3F??? Then why would you do it? The 2F has more cubes.
Has anyone retro fitted a small tb injection set up from a chevy? If you could take a 4bbl Offenhouser intake, and mount one of the TB from a 4.3??
Cheaper than a complete engine swap.
Thanks, this is exactly how I thought it would go. Thanks for this find.
I am doing the swap this weekend. I had to use the 1F Bellhousing, clutch and flywheel...and it all pretty much bolted up to the 3FE bolck. Used the FJ55 tranny and tcase. Got a new alumin radiator from speedway motors, and will be wiring it all up and hoping to get her running by this weekend or early next week.
Stumper - I have decided to go for the swap this weekend as well. Pretty much the same setup you are using with the 4-speed trany, flywheel off my F motor.
I got a ECU, engine wiring harness, rear pigtail (for power to ECU) circuit relay's from cruiserparts.net.
Wiring is what I see as the biggest challenge. Post back I would like to know how yours goes and any tips you might have. I'll do the same.
I am planning the same thing with my FJ-55, I have the extra 3FE A440F and t-case and I am dropping it in my 55 and making the crossmember and motor mounts. I have 2 FJ-62s to look at for wiring so I can provide pics if anyone needs them. Also, are you going to retain the smog stuff, gauges?
I am using the pwr steering pump from the 62 and a minitruck gear box. Not much smog on my 73 40 going to decide once the engine is in. Gauges 40.
Scott
