- Thread starter
- #61
Not sure, but it's 80 F here in NC todayAre you sure there is winter diesel in the tank?
I've already moved on from the Bosch and am using an all metal Toyota pump. All banjo washers are new and show no leaks.get the bosch hand pump and dont look back, factory one is junk
replace (or anneal) your copper washers on the pump line and re tighten
Progress report.
- 2 days ago I was able to fire it up with two bumps of starting fluid. It then idled for 10 minutes and I took it for a test ride, just a couple of blocks. It would restart normally while it was still hot. I found a fuel leak in the injector return pipe hose and added a new clamp there.
- 1 day ago - still wouldn't start with glows and diesel (I do see a 1.5-2v drop while glowing, also it was 82 F degrees outside, maybe 28 C). Again, 2 shots of starting fluid and I was again running. Took it on a slightly longer ride.
Good news is that the fuel seems to be holding overnight without letting in air. Bad news is that I'm having a hard time starting, despite good compression (395, 390, 380, 400). Another note/symptom - I am getting white smoke (too much fuel I believe). This is with a turbo that is pumping lots of air. Since I use a PTO cable as a cutoff, I tried to ween it off a bit to get a cleaner burn, but no luck.
I did have the IP off about 18 months ago to change the diaphragm. Does this sound like an IP timing issue? I'm thinking that it may be retarded - hard starts and white smoke. I should rotate it towards the engine a bit to advance the injection timing, correct? Thoughts?
The timing is at the stock marks. Given the compression numbers I have and the hard start/white smoke, do you have a more likely cause for that behavior that I can look into?White smoke and hard starts CAN be an indication of the timing being off.
You need to set the timing to stock at first to see if it changes behavior at all.
However since you have a turbo 3B, people tend to retard the timing on IDI engines when they turbo them.
