Some more point data that supports what those running skinnies already knew
I really wanted this test on tires that weren't showroom new. Like the worn in KM3, for example - is it more pliable, or is it just worn in?Man, I want to love this video. His points are usually spot on. IMO, his conclusion is ultimately inconclusive because of a bad assumption.
He states this is a true controlled variable experience with the only difference being width as they are both load range E and - has the same stiffness. That last assumption is not true.
Notably the tires have equivalent load handling only when inflated to very different pressures. With the narrows needing 80 PSI to the wides 65 PSI.
His experiments do more to show the fact the narrows have a more pliable sidewalls to the wides when at the same pressures. The wides having stiffer sidewalls.
I don't know if what you are saying is exactly right. The 35x10R17 has a max PSI of 80psi, but it reaches the max load at the same 65PSI as a Load E 35x12.5R17. I don't know how that affects the argument one way or the other.
Is having that data pertinent to considering real world use? How often are you running your tires over 40psi?Not sure I'm following? 255/85R17 is a funny size so I can't seem to find an inflation table. Did you find one?
I didn’t, but there was one for the 35x10R17 in your screenshot.Not sure I'm following? 255/85R17 is a funny size so I can't seem to find an inflation table. Did you find one?
Why do on road pressures have anything to do with this?
I hope Kai does a video on RUG and premium next![]()
