350 Rebuild
MOAB
I was gifted a 350 and I am unsure of the history. PO told me that it needs a rebuild. A friend and myself are going to be doing it.
Bore or not to bore.
Anyone have any advice on rebuild kits? They all the same? So far I have seen kits without pistons for around $150 and close to $300 with pistons.
I don't need crazy hp or torque. Want enough to go wheeling and to be able to tow here and there.
Thanks
if your tearing it apart and rebuilding bore it while your in there.
i would say bore it while it's apart, if nothing else you get a good fit when you put it back together.
i got my kit from performance auto warehouse in CA. it was ~$900 i think but i had to replace everything but the block... doh!
i have an eddlebrock carb and manifold, 9 to 1 pistons w/76cc chambers, hei, and a 214/214 cam. seems to have plenty of power to pull my 55 around even above 12000ft.
good luck, carl
bore or not to bore can't answered by us. It has to be answered by the motor once you get it apart. the bore it the minimum needed to clean up the cylinders. I have also found .030 to be pretty common. Your machine shop can tell you if you don't have the tools to mic it up yourself.
Don't bore if you don't need it. I hear people all the time talking up their engine - "It's a 350 bored sixty over" All that means to me is the engine is near junk. I wonder if those folks know why you bore an engine or even what they bored it sixty of.
No way to say it better than that. Nailed.
And to add to what Gumby said, An engine bored 60 over will run really hot, and most people never understand why. I will never bore more than 30 unless it is a customer that wants it done, and even then i try to talk them into another block, either new or used.
