343 shifting issues
Canby Oregon
So most of you know, I did the dirty deed, and swapped a 6bt into my TLC, and a 1" body lift, I cannot seem, to get it to shift correctly, I have tried manually shifting it, with the ECU unplugged and it seems to miss 2nd, I can drive it ok, but I am missing a gear, I am open for ideas, I have the TB cable set right
So I drove it a little more today, and I have no second gear for sure, it shifted great before the swap and body lift, I am manual shifting it, I must start in first and at about 15 mph I shift to second ( on the selector it shows that), but I can go 55 in second
Are you sure 1st is actually 1st? Is it possible the linkage didn't get pushed all the way back to 1st when you hooked it back up, so 1st is 2nd and 2nd is D?
Oh I know it's first, because I can't go very fast in first lik 10-15 MPH
Did you do a shift kit during this? I'd be chasing wiring first that is the new part. Did the trans controller come pre programed?
