3 Speed/ 4 Speed swap questions
Davis, OK, USA
Website
www.w5ji.com
I have an August 1974 FJ40 with stock three speed floor shift transmission and stock transfer case. I have a chance to get a 1973 FJ40 4 speed transmission and have been trying to determine if I can retrofit. I think I need to get a 4 speed upper and lower bell housing, but my main concern is whether I can use my stock transfer case. I've been researching it on the Internet and have been seeing some conflicting info.
The output spline on the 4 speed xmsn looks like a potential problem. It seems to be a finer toothed spline than on my 3 speed, based upon what I have read. I also have access to the transfer case that is currently on the 4 speed (for extra bucks!). Unfortunately the 4 speed is not local and I can't examine it directly.
A lot of my confusion is due to the fact that August 74 was the transition month for a lot of transmission items on the FJ40's. SOR doesn't list a different transfer case for the 4 speed, but some other suppliers seem to imply that gear changes are necessary. Since the 4 spped was offered from 9/73 onward, my thought is that my 8/74 transfer case may be OK.
I'm not interested in rock climbing, etc. I just want a fun driver. Any info to help me decipher the situation will be greatly appreciated.......Thanks
Gemco,
First of all, Welcome to Ih8Mud!!!
I know some, but not all.
If I were you, I would be wanting to bolt the 4 spd tranny to the 3 spd t-case.
The 3 speed t-case has a lower L range (~2.3:1) than the 4 spd t-case (~1.99:1)
I believe you rectify the difference in number of splines by getting a new gear (transfer case input gear?) that lets you bolt the 3 spd case to the 4 spd tranny...
HTH
That link generally discusses the swap of both trans/TC, but a popular swap is the 4 speed transmission to the 3 speed transfercase. Several vendors sell kits that have the right parts to do this. The result is a lower first gear in the 4 speed transmission + the lower low range of the 3 speed TC.
Post your progress.
Ed
Gemco,
It IS possible to mount a 3 speed transfer case to a 4 speed transmission, I've personally done it so post up if you have questions.
You will need a 4 speed bellhousing, a new tranny output gear (available from www.cruiserparts.net) an output bearing and you will require the shift linkage from the 4 speed transfer case including the front output shift fork.
Back door solution found......
Well I got lucky and found a 78 4-speed/transfer case combo for a very reasonable price. Now I'll just have to get a 4-speed bell housing and I should be OK. I did find several parts vendors who offer transfer case parts kits for $139 to $159 with all the pieces to update the 3-speed tranfer case to accept the spline on the 4-speed transmission. I was going that way until I lucked upon the combo.......... I'll post any problems that crop up with the 78 combo on a 74 F engine.
I currently plan to keep the original clutch rather than upgrade.
Thanks for the responses to my query. I appreciate all the help I can get.....
Does anyone know where I can find a shift linkage from the 4 speed transfer case and the front output shift fork?
This?
