For the first time my 92/3-FE (308K) has failed emissions here in Utah. I have read through all the threads I could find on the issue, and it seems that all of the remedies for them are parts that have already been replaced on my truck. The emissions test is broken down into a couple different categories, but my CO is the only thing that is high, the HC and NOx numbers were slightly elevated from last year, but below the threshold. The truck gets 10-12 mpgs which it always has ever since I bought it. Burns no oil, or gives any sense that something is not working correctly.
Here is what is new or has been checked:
FUEL:
Filter
Fuel Sock
Fuel pressure regulator
Fuel pressure damper
B&G 44K 2 cans anually
Both cats are new in the last 2 years, both Oxygen sensors were replaced with OEM Denso units at that time. Test was done after me driving on the interstate for an hour, with premium fuel. Truck has an EGR delete, and has during each of the past 3 inspections. Has never been an issue with the "sniffer test".
Valve job was completed this spring (it needed it).
Timing was verified at this time.
Last year I completed a top end rebuild, with all OEM parts; including head and pretty much all gaskets and hoses. I feel very confident there are no vacuum leaks. New dizzy, cap, wires, plugs, igniter; the spark/ignition system is in top shape.
Throttle position sensor verified IAW the FSM and everything checks out.
AFM checked IAW FSM all measurements within normal ranges.
Engine air filter is new. I think this covers all the solutions I have read in the other threads, that I do not think are applicable to my own.
So, high CO would indicate that incomplete combustion is happening, correct? So either it is running rich or unable to mix the fuel to air properly and ignite it. One thing I am curious about, the only thing I really didn't change on my engine was the fuel injectors. They now are 25 years old and have 300K+ miles on them. Is it possible if the spray is not completely aersolizing the fuel, that the fuel/air mixture is not happening efficiently enough, resulting in high CO? Would this have any other symptoms? My truck is as slow as any 3-FE, but will do 75mph on flat ground all day.
I appreciate any pointers. It is getting harder and harder to get these old trucks to pass inspections, would like to keep my rig on the road as long as I can.
FUEL:
Filter
Fuel Sock
