quick quiestion, what's a t04? the turbo? I'm turbo tarded.
Yeah, T04 is a turbocharger series. There are different "flavors" of T04 -- T04b, T04e, different aspect ratios and trims, etc.
I have the T04 35's and the 4.10 rear gears. I dont want to go any lower in high range.
I just need a way to cary more gas
any up dates
There's no room for a case between the tranny and TC. You got floor and gas tank issues.probably like the slee crawler box. the marlin would be between the tranny and transfer case.
There is a gear set available from rock hopper gears in AU they are lower than the marks set. I have just got done talking to them about a group buy and i'm going to start a new thread about it.
Link to recent group buy on this thread
https://forum.ih8mud.com/80-series-tech/240396-rock-hopper-gears-group-buy.html
You serious rock crawler dudes ought to be looking hard at that price. I bet Dan can't get you a set of stock gears for that money!
Scott J
94 FZJ80 Supercharged
Price and what Dan can get stock gears for is immaterial, it's about the utility. I can't speak for others, but know many that feel the same:
The primary use for my rig is touring, normal wheeling, a lot of it, between obstacles, etc is done at ~25 mph, so I'm not willing to give up normal low.
Rock crawling is a great diversion that I enjoy, but the '80 will never be great at it, it's too big, bulky, heavy, etc. That said, it's a fun precision driving challenge to see how far the big pig can be driven on/in the rocks. It's pretty much special olympics, handicap wheeling.![]()
So if there were a relatively easy to install, without major system changes, etc, crawler box available I would strongly consider it. IMHO the currently available options compromise what the rig is great at, to make something that the rig will never be great at somewhat better, so a compromise that I'm not willing to make.
Ha, that's a great description and perfect vision of a pig on the rocks!
Assuming you wheel in low, with stock tires and stock FD axles and Transfer, you are 4000rpm in second gear and 2700rpm in third at 25mph. That goes to 4300 in third with a 4:1 crawler, and 3250 in third with a 3:1 crawler.
Damn that's some fast speeds in low range IME. Why not just go 3200 in high range in first gear? You are sitting at peak engine torque to boot.
If the majority of your wheeling is 25mph, the price of a toybox seems better spent elsewhere to me.
Scott J
It all pretty simple really, if you had any off-road seat time you would know the answers?
Who would run stock tires on any trail where we are discussing the possability of crawler gears? So your numbers are off for my 37's.
High range sucks on the trail, different shift map, not enough torque to pull even the smallest ledges, little compression braking, etc.
Some trails are all obstacle, most aren't, so for most trail days; More miles are run at higher speed between obstacles, more time is spent at ~1 mph on obstacles.
Thankfully, for simplicity sake, Romer rock crawling with 33/4.11 vs 35/4.99 was much easier to consider. A lot of snoflakes is the main reason I stopped my calculations at the hub.
Good luck, let us know what you decide to do.
Scott J
Dont reference me in your discussion. I agree with Tools that you are arguing something you know nothing about and if you had any real offraod experaince would know it.
