leaking FI, result in long crank to start. Last part of fuel pressure test is, leak down test.@bubfuji , leaking fuel injectors normally cause a rich condition, not lean.
Thanks for the correction. I edited my post accordingly.@bubfuji , leaking fuel injectors normally cause a rich condition, not lean.
Usually I find disconnecting the battery is enough to reset all fuel trims. I've also cleared all codes with my scangauge. when I replace sensors I will do as you suggest and connect the terminals together to discharge any energy.
I'm not sure how to verify the voltages at the AFR sensors, would love to learn though. I assume only the AFR sensors are used for fuel trims and not o2 as well?
When you say the new air filter is not the issue, I'm not sure what you are talking about, what post are you referring to?
My autoline pro smoke tester comes tomorrow and I'm keen to plug that into my charcoal canister input and see what comes out. Also exhaust, evap line to the petrol tank, and air intake.
Well I ran smoke in there and found nothing for the intake. Nothing in the exhaust test was visible for now. Next up, I need to do that fuel pressure test. waiting for a banjo bolt to arrive. Charcoal canister wont get here for a month so I need to move on under the assumption that it has contributed a bit, but its not the whole problem.
However! I did see fuel vapour residue in the region where the resonator connects to the air tube. I'm guessing by the design, that can contain this stuff in there, some of this residue expected. But I want to know, is it normal? and where does it actually come from? Is it coming back out of the main vaccum line somehow (backflow?) or is it coming from the small line connected to the fuel pressure regulator?
Check this video and let me know what you reckon...
These fuel pumps have a resistor circuit that varies the pump speed, so they do some weird stuff when the pump gets weak. My wifes 100 had a cold stumbling issue for several years. It started getting worse, but only in the colder weather. Eventually the CEL came on when the LTFT's got bad enough. After digging into it and watching the STFT's, LTFT's, injector duty cycle and O2 sensor outputs, it had to be a fuel supply issue with correlation to pump speed. Under wide open throttle when the pump is running at 100%, eveything was normal - but cruising on the highway with little load (when the resistor curcuit is in play) the LTFT's were in the mid 20% to mid 30% range. Higher on bank 2, since that is further from the supply. As soon as I would floor it, the LTFT's were perfect again.@peacesells63 theres an interesting symptom for why I think it is going to be the fuel pump - after resetting fuel trims, the car never starts first crank. once started on the second crank, its got enough data to alter the STFT, and it starts. yes it could be a number of reasons, but it would make sense if it needs to do this to increase injector pulse to compensate for sub-optimal fuel delivery. I've realised I have everything I need to do fuel volume test, I just need the spec for the volume and duration I need. .95L per 30 seconds is what I get from chat GPT for a 2uz VVTI. any step by step instructions would be nice. I'm not sure if turning on the electronics in this car is going to automatically activate the fuel pump before I get a chance to activate the test in techstream.
I use Tech Stream (TS). I run TS Mini VCI, in Oracle virtualbox, running on windows XP. I do not log online to Toyota.Yeah its looking like tech stream might not be able to do a fuel flow test with my version and my mini vci which crashes. I also tried to activate the relay manually but I think its only one part of the chain and wont stay enabled for more that a few seconds. on ig (not engine running though).
I'm sure I'll be ok to do a fuel pressure test, but wondering how you guys activvate the pump manually to do a fuel flow test on a vvti @2001LC ?
maybe your mx+ tool can do active tests or something?
