2nd gen to LC fj80 bumper?
Never heard that.
Weirder has happened, you could always add some welds if you're hellbent on making it happen for whatever reason though. I expect the wings will be too narrow based on my bro-inlaw's old 4runner though.
Start with a quick measure of the framerail spread, then ask the same of the bumper seller. Assuming that's the deal here, right?
Anything is possible with a Lincoln. Measure frame rail and overall length.
It's going to take a lot of work. youre better off just building your own or buying one made for an 80.
I modified a second gen taco ARB to fit my t100. They're more similarly sized vehicles and it was still a nightmare. I had to create custom mounting, cut the bumper into 5 pieces, trim 4 of the pieces significantly while keeping in mind the tubes still had to fit back, then put it all back together.
Having owned both vehicles, I can definitely say that the front bumper mounts are completely different. The PU body width is also narrower. As others have said, unless you are up for a lot of customization, you're better off looking for one specifically for an 80.
