2LTE automatic ECU pin out
Reno Nevada
Does someone have the wire color and pin out to an 2LTE ECU. i'm trying to wire in the 2LTE from my stock motor which was an 2L
other info is the truck is an 84 toyota longbed that came stock with the 2.4 Diesel.
any help is much appreciated
It can be found here: Surf Maintenance
Or more specifically here: Dowloads & Articles
This wiring diagram is for a 70-series, but I believe the ECU is essentially the same. It should have all the info you need.
Ah, sorry, I didn't realize you were looking for the transmission computer. This should be the one. If you want the whole manual it is posted here: online manuals
I'm tryna get the pinout for this transmission box..
and the ect diagram in this link matches the 26 pin connector in the box but i can't read the diagram because it's blurry http://toyotasurf.asn.au/techsite/Images/2l-te_pinouts.jpg
In the full manual (link above) there is a 26-pin plug shown on page 62 that is for the transmission computer; it corresponds with the wires shown on the second diagram I posted.
I am assuming this is for an A343f transmission, otherwise none of the above applies.
