Hi!
My temperature reads zero all the time. So today I checked the connection to the sensor. Following Haynes manual I connected a ground to the sensor wire and turned the key to "ACC". The gauge did rise, so that works. Then I measured the resistance in the sensor (between sensor and ground), and it was ~400 Ohm. I think that is OK with a cold-ish engine. So then I connected the wire to the sensor and turned the key again - reads zero again. It shoudl move a little up at 400 Ohm, right?
I have probably overlooked something, but I can´t find out what I am missing here. Any suggestions?
