- Joined
- Dec 15, 2014
- Threads
- 19
- Messages
- 239
OK guys I really want to get this fixed. There is no reading whatsoever on my coolant temperature gauge. All the other gauges work perfectly. Here is what I have done so far. I removed the wire with the female terminal connector that is attached to the water temperature sensor located on the top of the motor on the carb side of the head and grounded it to/ on my firewall. When grounded it in this fashion the temperature gage obediently pegged all the way to the top. So I know that the dash gauge is working, and that there is continuity in the wire from the dash to the coolant temperature sensor. So all that was left was to replace the sensor itself, so I ordered an aftermarket one on eBay for $10. After installing it I went for a drive thinking I had solved my problem but the temperature gage did not budge at all again!
What else could it be?
So my question is... since my dash gauge works and there is continuity in my wire to the sensor itself would you buy another water temperature sensor? Or is there another piece to the puzzle that I have not considered? Those temperature sensors are such simple units you wouldn't think it would be possible to get a bad one but I may be wrong to assume this.
Thanks anyone want to take a stab at this? I would appreciate being pointed in the right direction.
