I have a bad wrist pin issue on a very low mileage rebuilt engine. Is there a simple fix? Do I need to rebuild the entire engine? If the only issue is the wrist pin, can I just replace the wrist pin/connecting rod/piston for that cylinder?
yeah - that's what I was thinking as well. Especially if it was lubrication related.You need to learn the root cause of the failure, before replacing any parts...
That's the problem. Had this done years ago; they are out of business.take it back to the guy who rebuilt it.
whay issue do you have?
how do you know about this issue?
Don't know. I had a local guy listen to it (who has a cruiser shop) and he said it was a wrist pin. He had the same issue in his cruiser, same noise, same location. So educated guess, not eyes on. I have someone that can fix just the cyclinder. He does super high end performance race engines.How did the wrist pin fail? Did one of the retaining circlips fail? If the wrist pin hit the cylinder wall, you're probably going to need to rebore or at least hone it good at the very least.
Just had an oil change - no bits of anything. Sound has been there since the rebuild. I agree it's an odd failure.right now, you're just guessing
what kind of noise is it?
to me it is an odd failure
how many miles on the rebuild?
have you drain the engine oil and look for bits?
if it is an internal engine noise your going to need to atleast remove the oil pan and see what you find.
