Is there any difference between a 1F (1970) and a 2F 1975 water pump, besides the shaft length? I think I have a circulation issue, and I am going to replace the water pump
There are only 2 pumps, with or without fan clutch. The F engine up to 75 uses the NON-fan clutch type (longer shaft) and the 2F uses the WITH-fan clutch type (shorter shaft.) And, yes, they do have different bolt patterns on the flange side so a non-fan clutch fan will not fit a fan clutch pump and vice versa.
Shes Mad said:I think South Boston disputed that. This 75 2F came with a long shaft, no clutch. the 1F is a shorter shaft, no clutch. Both bolted on, but only the 1F one will align my pulley's correctly. the 2F shaft is about an inch longer
Lowe Toyota said:There are only 2 pumps, with or without fan clutch. The F engine up to 75 uses the NON-fan clutch type (longer shaft) and the 2F uses the WITH-fan clutch type (shorter shaft.) And, yes, they do have different bolt patterns on the flange side so a non-fan clutch fan will not fit a fan clutch pump and vice versa.
hi guys . quick question. i have a 1978 fj45 with the 2f motor. just pulled my water pump out for replacement and it looks like the one on the right in the pictures above with the exception of the small inlet below the big one which is shorter and sealed on my pump. i have a two pulley set up on mine if this matters. info on my pump says gmb japan 3627. i am in perth australia. any one know where i can order a replacement and the correct info i need to do this. i am not mechanically minded and s*** scared of ordering the wrong part online but am flat broke so giving it a go to save a few bucks. all help would be appreciated thanks.
all advice is appreciated but when you say TRY this one i get a little nervous cause im to broke get it wrong. it looks identical to mine in everyway at a glance but online it says this pump is for 79 to 81 and my vehicle says it is 78 model truck but whos to say it is the origonal motor. tried to find out through serial number on engine but could not find it anywhere 2f 156037Try this one: Aisin WPT-063
