Is the "Gas Filter" vacuum fitting thingy (tri-pipe) that screws into the intake manifold a one way air fitting? Or can air flow through it in both directions?
Since neither port is a vacuum source, couldn't they both just simply be capped off, if you wanted to delete the CO?
Going back to the gas filter, all 3 that I checked had vacuum leaks around the ring. Two not bad, one almost no resistance. I put a solid bead of red loctite around the ring then applied a little bit of vacuum to suck it into the crack a bit. Worked well.
Hey man, Where did you get the tree from?Both ways. My guess it either as above or supposed to 'prevent or reduce' gas vapors from creeping into the vacuum lines when engine is shut off. I had one come apart and it's just wire mesh with some spun media in it.
I looked into replacing it with just a brass vacuum tree when mine broke, but since it was still available from Mr. T, I went with a new one.
Any pick n' pull junk yard will have dozens of them under the hoods of wrecked Japanese vehicles. I have a Ziploc of them somewhere but it would take a bunch of digging to find one. I'll look... I'd be happy to send one to you for the price of shipping.Hey man, Where did you get the tree from?
Man.....I want a single. How much? pm me if you prefer.Here are the 3 variations I have in my horde
single
double
and the tripple
I have seen other shapes and port configurations on other toyota Vehical s
But Never a 4 or quad port ?
View attachment 2392256View attachment 2392257View attachment 2392258
