2f exhaust question
Tacoma, WA
well, thinking about redoing my exhaust, as you can tell from the pic, its pretty booty. its basically just a late model 40 setup cut at the back of cat....thats it.
few pics to get the idea...
anyway, question is to my thoughts on the new setup. first, I dont plan on going with a header. I dont want to have to screw with it, i guess the stock design is cool with me.
so the question, using the stock manifold and taking my junk to the exhaust shop, can they mate the new setup to spacer coming off the manifold that has the two pipe outlet? Im pretty sure coming off the manifold direct wont work. any ideas? I dont want to use the double tube all the way down to the cat becuase the double tube may get crunched at a later by a big rock.
mike
edit, I searched too, didnt really find anything to answer my question.
Looks like we are talking about a 3FE in this rig. If that's the case, the stock manifold does not suck at all. Pretty decent in fact and I would not spend the money for a header (For comparision I put headers on all of the 2Fs I run).
Reconfigure the downpipes so that they "Y" together just ahead of the firewall, inside the engine bay. Install your O2 sensors in the abrieviated downpipes. From the "Y", run 2.5 inch exhaust and a good freeflowing muffler. 2.5 inch the rest of the way out the back.
Works great, sounds good, stays high and well away of all obstructions, and makes a noticable difference in seat of the pants performance (at least compared to the stock FJ62 exhaust system.
If you have to run a cat for legality, then run a single highflow cat (you may be able to skip the muffler too if you runa cat).
Edit: I just realized that I may be looking at one of those "twin down pipes off of a single manifold" setups that the '79 2Fs had. In that case... get a header. ;)
Mark...
From my view... looks like a later 2F exit pipe also known as a "turd" in the pic below... I see a header in your future....
Michael, as the exploded pic in this thread shows, the exhaust originates from a single orafice, then has a plenum attached to the manifold to split it in two. If you want to take the time to make a flange that matches the manifold AT THE PLENUM, you can have a traditional pipe fabbed from that point.
Your exhaust manifold is one of the better ones Toyota made, being of the three piece design.
I would still prefer the header option, but I know your budget!;p
Best
Mark A.
Anything is possible if you have enough talent or money. Why bother, since you need to pass smog in CA anyway? Why worry about crushing the double tube? At least you will have the other half to flow. If it gets messed up, then worry about it.
Best
Mark A.
Mark, Its not really the budget actually, more of a preference. I was thinking about a header for a while, but I heard some negative comments like it will never sit right, or it will have to be adjusted frequently etc. I know the topic can go both ways, and I didn’t really want to get into that debate. But on the other hand, I know the benefits so perhaps I will have to re-think a header… Maybe I will consider that flange option. I didnt know if running such a thin tube (like your standard exhaust pipe) would be ok that close to the motor. I thought about it and it seems it would be far to hot and material too thin. I'm really unfamiliar with exhaust so hang in there with me for a minute.
Pinhead, I don’t have to worry about the smog restrictions because the truck is a ‘73. Thanks for the ideas so far.
If it is a '73, then there is no need for the catalytic converter. Run a SOR (Downey) header (Mine fits great with no leaks) and run it inside the frame rails and back. It's brilliant. I did it with mine and was able to keep the CAT (had too). It is much better protected and with the header, hi-flow cat and Flowmaster Hushpower (slick and low profile) muffler, it has more power and I nice rumble.
No problem at all.
Mark...
Mike likes to run the Catalytic converters because he is an enviromentlist, he wants to be apart of the solution and not the problem
Or he just doesn't like the stink of a cat-less motor. It's nice to not suffocate if you end up in line in your rig at the drive-thru window . . .
I just put a two piece SOR header on mine. I had a six into one header before and it cracked between #3 and #4 cylinders. Hopefully the two pice (three into one,three into one) will work a bit better. It came ceramic coated.
Also, SOR has an exhaust system that doesn't require welding to install. Exhaust exits the truck on the left side behind the rear tire. I've installed the system and an really happy with it. It set me back about $800.00. It's cheap when I think of how long the system will last.
Yes, I'm changing the environment... ask me how:grinpimp: Really, I kept it because my profession requires me to move every three years or so and I don't want to get caught by the smog nazi's. (It's straight-pipe replacable) shhhhh!
Thanks for the back-up Mr.Toad!
Come-on, I'm in Canada, the home of the diesel Cruiser... My stink is the least of my worries:D I also get strange cravings for Kalamari after following one particular BJ60 though;)
I also get "Geez, your truck is really quiet for a diesel".
Hi All:
If your stock exhaust manifold is not cracked/leaking, why replace it?
My FJ40 has a header on it, and one thing folks never mention about headers is how hot they run.
Not a problem during the wintertime. But during the summer the heat is noticable.
Now, I have heard that a one inch body lift allows enough extra air flow that the increased temperature from the header is less an issue.
For exhaust system fab I recommend finding a shop with some old timers working there, the type that know how to custom bend tubing. The "Midas" type exhaust shops generally have no idea how to build an emissions system for a trail rig.
BTW - nice looking Land Cruiser!
Regards,
Alan
Mike-
I would just call around or take the rig down to a couple of shops (Ryan and Georg should know of a few good ones in Stockton) and see if they can fab the flange and do the exhaust. MufflerTech on Florin Rd in S Sac did a really nice job on mine including fabing a flange to mate my Downey header to 2.5" tube above the frame and a turbo muffler for ~$160. Any shop worth a damn should be able to get you what you need.
-Brian
Thanks for all the replys guys, the environmentalist thing was funny. Actually, my exhaust sucks and that cat on there is about worthless. my eyes water at stop lights now i have the hard top back on.
I think I have decided to talk to a few local folks at the exhaust shops and see what they come back with. thanks for the info brian, ill give them a call and see what they come back with.
greenfox came by tonight and were going to check some of the vacuum routing and tweak with the timing.
i may be wrong but i think you can take the pipe and adapter off and run a stock 3 bolt pipe from a 78 and go from there i have the same setup you do but its tucked in more and is the only system i havnt smashed yet have less rocks but a lot more dead trees and stumps good luck
OOPs, Wrong Mike... My bad.
Quote:
Yes, I'm changing the environment... ask me how Really, I kept it because my profession requires me to move every three years or so and I don't want to get caught by the smog nazi's. (It's straight-pipe replacable) shhhhh!
