- Location
- United States
I need a 2F Crank Pulley/Harmonic Balancer with 2 grooves for a '76 2F. Mine wobbles because the key way has been torn up thanks to a forced installation. PM if you have one.
lbrillhart, in case you happen to see a 'want' ad yourself, that pulley would have been used on a 73-74 model. Narrow outer belt for the smog pump, wider inside belt for the alternator, F engine.
65swb45 and lbrilhart
Would the narrow pulley groove be compatible with a GM power steering pump pulley? I am collecting parts to do pwr on a 1971 40 with a stock F engine.
F-Junker,
I'll take your pully as long as it has the wide grooves. I'll pm you as well.
