At a minimum I’d pull the water pump and look inside that hole and see what’s there. Then make a decision.
If you can get them out, I'd look where the water temperature sensors go into the head.
I pulled out the water sender and a brass hose barb where I think @RAGINGMATT said should have been an L shaped fitting. I found it to be dirty as I think I would expect it to be, but I don't think a lot of flow will get through there.
Then I saw this particular fitting to the right of these two
I guess the PO didn't have enough plugs, so he used a plug...spark plug.
What is supposed to go here?
thats a AIR injection Rail Port ,
I had no idea u could take a Fine thread OEM Nippondenso Spark Plug and make that kinda work like that
Thats a First ..........
This could lead to a new fashion statement when de-smogging. A new, full set of Nippys down the drivers side.
I pulled out the water sender and a brass hose barb where I think @RAGINGMATT said should have been.
I had a little time to start tearing into my new to me 2F. Pulled the upper oil cooler hose and found the thermostat housing port to the cooler was plugged completely.
Then pulled the water pump hose and found it to be plugged too.
Question...is this stop leak? If so, is there a concern that any of the passages in the engine could be plugged as well? I plan to install a new water pump, hoses and clean out the thermostat housing, but didn't plan on tearing too far into the engine, except gaskets, etc.
Next question...since the cooling system is pretty much ineffective, could there be damage to the engine due to overheating?
We had a 40 that sat for 15 years and all the coolant evaporated and left the same kind of thing in the pump at t-housing.
A solid plug of chalky crap mixed with a little green.
The rings were frozen, 30~50 initial compression per cylinder. Nothing to lose so we replaced the front parts and fill the engine
with engine flush, marvel mystery squirted in the cylinders and got it running til it warmed up. Drained the block and did it again.
Second flush looked much better. Filled the bock with Evaporust and let it sit overnight. Drained it and filled with water. Ran it again.
Third flush and the water came out pretty clean. Eventually got the compression back to the 135~145 across all 6. Still runs great five years later.
Besides the many off the shelf block flushes...
Oxalic acid in a solution works well and doesn't hurt anything else in the cooling system
If it's really bad a 3% muratic is more aggressive but very effective.
I would use it if I were going to replace the radiator anyway and I would bypass the heater circuit with this one..
Arm and Hammer Washing soda ( not baking soda ) is another safe wash.
Whatever you use you should flush with clean water thoroughly afterwards.
Sure is nice to know your seller is gonna make it right. Now ya gotta figure out which option best suits you.
