I had a little time to start tearing into my new to me 2F. Pulled the upper oil cooler hose and found the thermostat housing port to the cooler was plugged completely.
Then pulled the water pump hose and found it to be plugged too.
Question...is this stop leak? If so, is there a concern that any of the passages in the engine could be plugged as well? I plan to install a new water pump, hoses and clean out the thermostat housing, but didn't plan on tearing too far into the engine, except gaskets, etc.
Next question...since the cooling system is pretty much ineffective, could there be damage to the engine due to overheating?
