Hi all, new here...
Anyway my question is about the stock 2f Carby. I've had two rigs with pretty stock 2f engines - a 45 and a 40 series. Both were in good mechanical order and had extractors. The 45 was mated to a 4 speed and my shorty has a 5 speed box. The difference in power is what makes me wonder about the carby or even if my shorty motor has been worked in some way before I got it. With my 45 it used to run like I thought a 2f was supposed to - a solid, torquey motor that will lug all day but will never be a quick truck. My shorty is a different kettle of fish. I must mention that it has a full fibreglass body so the power to weight ratio is much improved but there has to be more to it. It's like the motor has two operating modes - a normal one like my 45 used to run at but when you give it a boot-full of gas it really goes hard when it gets over a certain number of revs (I would only be guessing what RPM I'm talking about). It's not like it throws you back in your seat or anything but the increase in power is awesome compared to what my 45 had. It has a much higher top speed as well - when I first bought the shorty I wound it up to 140kph (appx. 88mph), and it got there pretty quick too with more to give untill I backed off because the original stiff suspension was starting to bounce the rig around!!! My 45 was flat-out at 120kph (appx. 75mph), only a 4 speed I know but it took an awful long time to get there and if my 5 speed is stock then the gear ratio's from 1 to 4 should be the same.
So, with the power boost that I get my old man reckons it's just the second barrel of the carby opening up but my 45 never had a power increase like this. Perhaps the carb in the 45 never worked right???
Could it be the carby like my old man says or is it more likely that the motor was worked in some way when the truck was rebuilt for galvanised chassis and fibreglass body before I got it? If the motor has been worked in some way what mod could make it increase in power like this?
Any thoughts? and does the second barrel of the carb work like this and at what point does it kick in (RPM's)??
