I have been researching tires on MUD ever since I got my 80 back in 2004 waiting for the current 275/70's to wear out. I have researched the 265 vs 285 threads to death, but until I actually drive with larger tires I will never know. I am hoping to get swayed one way or the other by this thread and apologize for any repeat information as I know this topic is covered frequently.
My rig is primarily used for family trips across Washington in the winter where we will cross a mountain pass (4k max elevation) and go through the Columbia River gorge which is a fairly steep grade, but all relatively low in elevation compared to the Colorado passes. We don't tow anything during these trips.
I want 285's for a little extra lift during winter logging road excursions, but don't want to hit 2nd gear repeatedly when crossing WA mountain passes with the family. If I go with 285's I plan to install Slee's speedo correction gear as well to help with the shift points. If 2nd gear is my fate with 285's then I will most likely go the 265 route instead. I have no plans to regear for 285's.
I get nervous when I read threads like:
What also concerns me there are muliptle threads where someone was trying to make the same decision, got 265's and now wish they had gone with 285's. Examples:
I am really torn between the 2 sizes and can’t seem to be swung one way or the other. Any help would be much appreciated.
BTW...currently, running OME 861/862 low height springs with no plans for more lift.
Thanks,
Russell
I drove the 80 from southern Idaho last weekend, and had to hit 2nd gear several times that I don't usually have to with the 265s, white bird hill and the lewiston grade. Granted, I had 7 people in there with some gear as well, but still....
After reading all the tire threads I decided to go with Revo's. But I let the tire guy talk me out of the bigger size. 'Louder, rougher ride, odometer is off...blah blah blah...wife won't like 'em, blah blah blah.'
I gave in and got the smaller 265's. I wish now that I hadn't.
Yes I am running 265/75 sized tires! And Yes I do regret it! I should of went with 285/75/16.
Ashooter,
That is a tall skinny tire, are you unhappy witht he 265-75-16 you have on now or is this just due to needing replacements? I have the same size and kind of wish I had gone to the 285 series, especially since I am looking to gain about 2" when I replace the sagging springs.
Glen
Thanks,
Russell
. I think youre fine, and the extra clearance will help on your logging trips.
So if you aren't hitting 2nd on the Lewiston grade I should have no problems on Snoqualmie or Stevens. Basically, you are only shifting out of overdrive and maintaining a decent speed with some meaty MT's to boot. Good to know. Your post is leaning me even more toward 285's...
