Howdy,
I had a quick question about tire sizes and gas mileage. I will be taking a 3000-3500 mile trip this summer through washington, Oregon, CA, Utah, Nevada, and Wyoming. I'll only be doing city driving for about 2 weeks in CA, and the rest will be mostly freeway driving with the occasional pass to climb.
Question:
Will my 285 wildcat LTs (d rated) with steelies get better mileage (using a gps for this) than my 265 wildcat ATs (c rated) with the stock wheels?
Things to consider:
1. I will be doing a LOT of freeway driving in the 65-75 mph range on flat(ish) ground--Central CA, Eastern Washington, Nevada, Utah, southern Wyoming, Southern Idaho, and the bigger tires will bring my RPM range down, I am at about 64mph when the speedo says 60. The most efficient speed for this rig is 55-60, so the closer I can get the speedo to that, regardless of actual speed, the better I should do.
2. The steelies and 285s are significantly heavier than the 265s and alloys.
3. I will need to climb several passes, Donner, big horn mountains, cascade range, etc plus I will be on Hwy 1 in oregon for a hundred miles or so, and may stop at the dunes....
So, What do you folks think will give me the best mileage overall?
I picked up about 3mpg in my T100 running the 285s from southern Idaho to Moscow, but I don't know if the same will work on the 80.
Thanks,
Dan
PS, I know that it will be low either way, but with any luck I'll save enough gas to be able to stop off and buy a beer for a couple of you along the way.
Question:
Things to consider:
Thanks,
Dan
