I installed the gear: 33403-69225 in my US spec 1997 FZJ80 with a 1FZFE and A343 transmission. In the US I think all speedometers went to sensor/wire with the shift to the FZJ80 and away from the earlier FJ80 though I'm not totally sure on that. Here's a post for some reference:
OK, I'll admit it, I'm too busy (OK, lazy
) to try and figure it out myself, but it's been on my mind so I'll ask since you guys are so good technically and reasonably forgiving
Now, IIRC, there is a cable coming out of the trans (or is it TC) for speed info. I assume it's a mechanical cable from what I remember of it (thick, O ring at the case for oil etc). Yet, it seems like the speedo is electronically controlled from what I remember reading here (may be wrong).
So, if it is an electronic speedo (is it?) and if it's a mechanical cable (is it?), what's with that...
Near the end of the thread ToolsRUs says he thinks the gear works for both cable and sensor setups, which makes me believe that's likely true. Not sure if the gear will work in your 80 or not but it's worth looking into as an inexpensive, simple and solid way to keep your speedometer accurate with 285s without adding more points of failure, complexity. I think I paid around $25 for the part and I've confirmed my speedo readings with gps across a range of speeds and it's very accurate.
