Would asking the dealer to use 5w-30 void the warranty?
I dont know.
If my warranty is voided so be it. Realistically Magnuson Moss act probably protects you.
Yeah. If you are out of the recall and your engine goes kaput, I would think Lexus could argue it may have been because of the "out of spec" oil, but I think they would have to show evidence of this link if you bring them to court. On top of lawyers, experts would be involved, and bills would quickly become astronomical.I dont know.
Yes i saw he didnt technically point to 0w20 but the inference basically he is pointing out is to stick with manufacturer oil recommendations.Interesting. He is pointing to the 0W-8 oil, technically. He also suggests that it might be fine to have oil that's marginally more viscous (the bottle adjacent to the one your car says to use), so still think it could be fine for 5w-30....maybe...?
The clearances in the V35 are not tighter than old engines. He could state that and just mention that using a different oil could void your warranty.I think it's to avoid legal issue. If he's advising people on what oil to use and per Lexus, it's not the recommended weight. Even for his shop, he would need to follow the recommended weight because if s***s hits the fan, he could take blame for it.
He's a shop owner first and creator second. If the owner of car said hey use 5w30 on mine, I'm pretty sure he'll do it. He just won't recommend it because he can get sued if something goes wrong.The clearances in the V35 are not tighter than old engines. He could state that and just mention that using a different oil could void your warranty.
Some of these creators create videos that do not provide any benefit other than getting views. This was one of them.
I think the pump is mechanical on these and I could not find an oil pump or oil controller that had different part #s than overseas v35s.We need to get comfortable with the fact that we will never have a credible confirmation that 5w/30 is 100% OK on US spec vehicles. Nor will we ever get 100% confirmation that it’s not.
The video does bring up an interesting point on programming of the oil pump which is certainly worth incorporating into your preference between factory recommended and 5w/30. We had a cold snap up here in New England and I’m running 5w/30. Did have very high readings on oil pressure until engine reached operating temp. This may be identical in 0w30 but I don’t know.
As for viscosity vs design…..spoke with some folks who are more “in the know” than most.
Likely design. Exact causal factor unknown. Timeframe for long term change unknown.
I’m just going to drive and enjoy this rig with confidence knowing that the answer will come and Lexus will stand by it’s product.
I’ll also be switching back to factory recommended just to avoid any potential negative impact on qualification for replacement later reinforced by the knowledge that it’s not viscosity causing the failures.
Great insight.I think the pump is mechanical on these and I could not find an oil pump or oil controller that had different part #s than overseas v35s.
The pump is 100% mechanical. It is chain driven off the crankshaft. This is directly from Toyota.I think the pump is mechanical on these and I could not find an oil pump or oil controller that had different part #s than overseas v35s.
Correct. The 3UR has tighter oil clearances than the V35A.The clearances in the V35 are not tighter than old engines. He could state that and just mention that using a different oil could void your warranty.
