#25 Silver 147 wheel well widening, bodywork and paint.
kelly saad
Supporting Vendor
GOLD Star
Flagstaff Arizona
It has been a while since I have uploaded project threads like I was previously doing a few years ago. This project is almost done, but I will upload pictures over the next week and go through the whole process here.
The project:
1. Disassemble vehicle: remove doors, tailgate and hatch.
2. Strip paint to bare metal.
3. Close all holes in rocker panels from trim.
4. Remove seam sealer in roof gutters and windshield area, repair any rust and seal again.
5. Fabricate new lower door skin replacement panels. Sand blast remaining rust, seal bare metal and apply seam sealer.
6. Fabricate quarter panels and fenders to allow the 37" tires without interference.
7. Remove, clean and replace A-pillar gutter sections.
8. Fabricate inner front and rear inner fenders to fit the new opening shape.
9. Paint (base and clear) Toyota paint code 147.
For a project like this, it's best to remove the entire panel.
Lower door skin sections are being replaced also. I always replace these because all of these 60 doors have hidden rust in the bottom. I fabricate the lower skins myself. This requires an english wheel, brake, bead roller and a slip roller. The doors are not flat, so if you don't create these with the correct shape they will not look right.
Wow, that widening the fender opening while keeping the original body line is really cool. I want to do that on mine
Thanks! It looks so awesome, honestly. It was a massive project! Undershot my landing on this one for sure. The inner fenders were a huge part of the job too, getting these to fit perfectly to the fender and quarter lip. Organic shaped parts with bends in multiple directions, tough.
This is an example of one lower door skin installed start to finish. I made a brace that goes behind the seam while I weld these. It has an aluminium face and a slight bulge outward to keep it from caving inward. It is just wedged in and removes easily for the next door.
The rear quarter panel wheel opening project. This took a couple donor quarters to create the panel I needed. The small silver piece is the front 3.5" from the original quarter and I will use it here to push back the wheel opening. Also, the lower section of the quarter will be removed for more clearance and so I decided to also remove the bumper indentation.
This is the drivers side quarter panel. Last picture is the test fit. The third picture is a close up of the tig welds. I overlap the panels and cut through both at a bout a 45 degree angle with a small saw blade. Then tig weld the pieces together without a filler rod. There is a mig weld tack in there, so you can see the size difference.
