Ive been working on my bad running '86 truck 22re. Timing was WAY advanced, like 40+ degrees btdc at all times. Using my service manual and ohm meter I adjusted my tps and now at idle I'm getting 5deg btdc with the two prong connector shorted, and about 12 deg btdc normal not shorted. However, as I open the thottle the timing jumps back to 40+ degrees very advanced. It will settle back to 12 deg when I let off the throttle.
Is this still a symptom of a bad or misadjusted tps? What kind of total advance should I be seeing when opening up the throttle? Any other reason the computer would want to advance my timing so much? Thanks.
