22re throttle body breakdown
@Mashr, those TB shafts seals are not sold separately through Toyota. That’s why I had to find them elsewhere.
Not the shaft seals. The large Squarish one that separates the two halves.
I would love to find some button head allens so if anyone knows where I can get some M3.5x60 allens please let me know.
McMaster Carr sells them. They also have a torx option.
M3.5-6mm, allen
94500A277 - 316 stainless button head hex ($4.93/100)
92095A159 - 18-8 stainless button head hex ($4.00/100)
92290A860 - 316 stainless socket head hex ($10.89/5)
91292A347 - 18-8 stainless socket head hex ($9.11/5)
M3.5-6mm, torx
90362A158 - 18-8 stainless pan head torx ($10.96/100)
90991A116 - 18-8 stainless button head torx ($6.04/100)
Thanks for posting that tear down. I always assumed the shaft seals were brass - you learn something every day.
I'm kind of thinking if you tore it down and put it in a ultrasonic cleaner it would look extra purdy!
@Toast I finally acquired a Throttle body, have cleaned it mostly up and have it on the bench. Going to replace the Idle Air gasket and the Idle o ring, but thinking about these shaft seals. I really don't want to have to drill out the butterfly screws, is it possible to get the seals off the shaft in place? The throttle spring side has a spool on it with the spring wrapped around it, I removed the nut on the end and pulled a bit on it but it did not budge.
In a thread on YT, a guy there says it is possible to change seals without removing butterfly and shaft, but he did not say how.
Edit: Here is the thread on YT that mentions changing shaft seals without removing butterfly: 22RE Throttle body shaft seals / rebuild - YotaTech Forums - https://www.yotatech.com/forums/f116/22re-throttle-body-shaft-seals-rebuild-313039/
Just looking at one of my TBs right now. Confirming what I think is obvious... the TPS flap should be installed oriented close to vertical in line with the throttle plate with dot to the right if viewed from the side?
I looked at one of my spares and it was 90 degrees off, so I swapped in the one with the newest TPS, and it works fine. One day I will get around to doing a full reman on some of my TBs. Thanks for the great thread. I spent hours trying to set a new TPS, and then I thought it felt funny, so I looked back through your thread, pulled off the TPS, and compared it to some of my other ones. I got it and an entire engine from a kid who said it had been running. Block had a blown crank bearing. Never thought to look at the TB, in case he had messed with it, but I should have. Lesson learned.
