- Joined
- Jan 7, 2009
- Threads
- 1
- Messages
- 7
Hi, just new to the forum, LOVE it!
Anyway I have a 88 toyota with a 22re, it hasn't been run much over the past several years. Recently starting using it but, the engine is cutting out throughout the RPM range and occasionally the check engine light comes on(mainly when you are at a high RPM and let off the gas) soon as the engine gets back to idle the light goes off. Took it to my mechanic after trying a few things and he is also puzzled over it. Says the O2 sensor is fine, the TPS is fine, new cap and rotor, new fuel filter, plug wires are fine. I have changed the MAF settings on it but it ran fine for a couple of years after I did that(its all sealed up so, no moisture), since then nothing has been changed on it. It also misses at an idle.
Any ideas?
Any ideas?
