- Joined
- Sep 9, 2004
- Threads
- 186
- Messages
- 13,327
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
Cheers
Per @Onur, this FTE short block was manufactured by Toyota on February 4, 2021. I’ve got veggies in my fridge older than this thing.
The engines are not any different but you will have a slightly different wiring harness. The biggest issue so far is this truck came with the CAN Bus wiring setup and that doesn’t cross over so nicely with the 1HD engines. We are going to be running HZ wiring harnesses from a new model HZJ79 and have that adapted to work with the 1HDFTM. Should result in a very clean and uncomplicated setup. Not saying you cannot make the 1HD variety work in the CAN bus environment but we are going to take a different route.Just for education sake, will a 1HD engine from a RHD cruiser work in a LHD cruiser, or was this part of the reason this was purchased? I’ve always wanted a 70 series w/ this engine, and have kicked around the idea of doing something here in Angola at some point, but all the 1HD engines will likely be from RHD 80/100’s in Namibia/RZA/imported vehicles. Furthermore, what would a new short block set you back?
In my neck of the woods, coming across a 1HZ powered Troopy, 76, 79 double/single cab is easy peasy. It’s the 1HD’s that are a challenge. Can you get a new long block from Toyota or Partsouq? An aquaintance of mine in Cape Town rebuilt a 1HD-T to better than OEM (port/polish/blueprint), and it cost him roughly $10k installed in the clients new Troopy. That’s kind of my angle. Is this better to source a RHD engine one day and rebuild for LHD or is it better to buy new. Anyways, I’m loving this thread and @TonyP ‘s thread. 1HD in a 70... I have to pull my self away from watching and reading, lol...The engines are not any different but you will have a slightly different wiring harness. The biggest issue so far is this truck came with the CAN Bus wiring setup and that doesn’t cross over so nicely with the 1HD engines. We are going to be running HZ wiring harnesses from a new model HZJ79 and have that adapted to work with the 1HDFTM. Should result in a very clean and uncomplicated setup. Not saying you cannot make the 1HD variety work in the CAN bus environment but we are going to take a different route.
As for price, the short blocks sometime show up on Partsouq and run about $5500 landed in the US. The only downside to a new short block is the rest of your engine will not look as good and you end up buying all new everything. Next thing you know you spent $25,000 on a new engine and you still haven’t seen the Gturbo bill.......The bits and pieces to make it nice and shiny add up real quick.
No more long blocks available new. The one I got for the 80 series was around $14k landed.In my neck of the woods, coming across a 1HZ powered Troopy, 76, 79 double/single cab is easy peasy. It’s the 1HD’s that are a challenge. Can you get a new long block from Toyota or Partsouq? An aquaintance of mine in Cape Town rebuilt a 1HD-T to better than OEM (port/polish/blueprint), and it cost him roughly $10k installed in the clients new Troopy. That’s kind of my angle. Is this better to source a RHD engine one day and rebuild for LHD or is it better to buy new. Anyways, I’m loving this thread and @TonyP ‘s thread. 1HD in a 70... I have to pull my self away from watching and reading, lol...
Okay I’m still blown away at this $10k number. I’m not saying your friend is full of it, but I don’t see how you could do the rebuild and the swap at a shop for $10k even if the parts were given to you for free and the machine shop did not charge you.In my neck of the woods, coming across a 1HZ powered Troopy, 76, 79 double/single cab is easy peasy. It’s the 1HD’s that are a challenge. Can you get a new long block from Toyota or Partsouq? An aquaintance of mine in Cape Town rebuilt a 1HD-T to better than OEM (port/polish/blueprint), and it cost him roughly $10k installed in the clients new Troopy. That’s kind of my angle. Is this better to source a RHD engine one day and rebuild for LHD or is it better to buy new. Anyways, I’m loving this thread and @TonyP ‘s thread. 1HD in a 70... I have to pull my self away from watching and reading, lol...
Either way. You should absolutely acquire a new HZJ Troopy or Double Cab, gut the engine/transmission and swap in a FT/H152. You can get some decent money for a brand new 1HZ takeout. It would be an insanely easy swap and the final result would be worth it.Yeah, it was in South Africa and he did it a few years ago. I’m probably off on that. Maybe that was the price of the rebuild alone. The Rand has crashed over the past 5 yrs so it’s probably a good bit more now.
