Build 2016 TLC build
I just got my 200 back last night. Toyota took care of it. They replaced a section of the harness and the knock sensor and didn't charge me a cent. Big thanks to JSP and Mike at Wilsonville Toyota for making this right.
I pulled those ridiculous running boards off too.
I'm still collecting parts for the Airbag light fix. Stay tuned for a write up!
Congrats! I'm continually surprised at the customer service the Toyota/Lexus dealers supply. @luke27617 is spot on with his view. Thank you for updating on that piece.
@PDXLX -wondering what your overall build plans are?
Essentially a bugout for two with a maximum amount of lockable interior storage.
I'm even toying with the idea of importing a 180L Long Ranger.
47 Gallon Long Ranger Aux Tank installation USA 200 series...
Yes! The LC is quite possibly the ultimate buyout vehicle--except for the fact that it would be highly sought after in that scenario :eek:. If you ever figure out how to successfully do a long-ranger here...do share. I'm interested, as are others. So far, it's an expensive pain plus regulations out the wazoo in many states...
Something to consider for turn signals as I have as well changed all non-LED bulbs in my 16LC. I have not tried the plasma bulbs but have notice with regular bulbs the front was not bright enough for people to see it well. I went with my trusted source from vleds.com and bought for front v3 triton and for the back since there is not enough room their high visibility 7443. Even those 7443 are very bright, still cannot match the fronts. Those V3 are amazing. Since you have your set already coming, please share your experience and maybe a video. Thx
Did you need to install the resistors for those v3 triton you installed on the front?
Unfortunately so. I was hoping I wouldn't have to but and only installed the rear at first. Hyper flash was still present so I did need to install the resistors under the hood as well.
Ok. There appears to be some interest in this. The process took a bit and I needed to leave my truck at their shop for a week or so.
I'm going to contact the guys that did this and see if they can pump out a batch that can be easily DIY installed. They can use my truck as a base. I'm not sure if the USB option will be that simple to DIY but they maybe with a bit more noodling they can figure out a plug and play there too.
Give me some time and I'll repost.
Any follow up on this and getting the plastic inserts?
Regards,
Peter
You can get plug and play resistors with V3. If you do install at front only you need the 6ohm package. If you are doing turn signals for the back too, then 3ohm for the front which will cover back too.
New to the forum - I have a 2016. Curious if you have anything on the head rest covers. I've pulled mine out as well.
