...So my question is when installing the CDL switch, you have to pull out the Blank Space Holder on the dash to reach the screws. Is their anyway of not breaking the blank space holder?
what is a ds?Really easy. Got a hitch backup camera. Pulled the wires up along the tail gate through the stoplight (you will need to make the connections there in order to make the screen light up and the camera to work when shifting the tranny in reverse), cut a slit in the wire cover going inside the trunk, routed the wires through the door sills across the DS, up the dashboard into that location. Pull a positive wire from the battery and made the connection with the display.
Now the trick is to drill some holes in that useless cubby and not break it. It's old brittle plastic. One little mistake and it will shatter.
Start with a small bit and work your way up to the diameter of the screws. Don't force anything. Make sure you only need to drill once, measure 5 times prior.
free tip. make a paper template first to see where the holes would need to be placed.
Get the paper template lined up with the plastic cubby and mark on the plastic where the holes should be.
READ: https://forum.ih8mud.com/threads/fa...attery-information-thread.84888/#post-1012334W
what is a ds?
ERM is probably and error because he's using his cell phone and voice command. as a full time teacher of 15 year olds(freshman) I see that stuff on almost every paper they turn in. None of our youth today can type worth a damn. They talk into their phones and then send that to their emails and cut and paste it into Word. its funny as hell reading their papers. they almost never proof read or spell check anything they turn in.whatever their phone thinks they said is what shows up in the paper.ERm i live in Alameda, California..
What is ERm? were you born in cali? Just curious.
