2014 LC headlight flicker
Thomasville Georgia
Noticed the other night that it appeared the driver LED headlight low beam was flickering just a bit. Tonight noticed that passenger side was doing same when I was driving. Noticed on cars ahead of me while stopped at stop light. More of an annoyance than real issue but concerned that the entire light could go down at night. Any suggestions for fix would be appreciated or experienced with same issue. Thanks in advance
I had a flicker. Replaced the bulbs and all good. Changing the drivers side is a bit challenging. Here’s a good thread on the topic:
It can be your bulbs or it can be also the ballast. change the bulbs first. both happened to me on my 14 too.
Is it actual flicker or just the bulbs bouncing around on bumps? Aka jiggle. 13-15 xenon lamps are especially bad about it, even when brand new and working perfectly.
No. It’s a flicker. Now notice on garage wall when parked. Thanks
Yeah, that’s definitely not the original issue.
I don’t see it mentioned yet.. what year is your rig?
You state LED and that only came from the factory on 16+
