For Sale 2009 Tacoma TRD Off-Road w/ factory Tow Package
Status
Not open for further replies.
Houston,Tx USA
Year
2009
  1. Tacoma Gen2
Mileage
196000
Color
red
Up for sale is my 2009 Barcelona Red Mica Metallic Tacoma TRD Off Road Double cab short bed. This truck was originally sold from Fred Haas Toyota here in Houston,Tx and later spent some time in the Dallas/Fort Worth area. My cousin bought this truck in 2016 at 62,000 miles and kept it as his daily vehicle in the Denton,Tx area. He's maintained this truck very well and babied it. It's been it off road at marble falls once but not through trails more than 2 stars. I bought the truck from him in April of 2023 at 178,000 miles. The truck currently has 196,000 and I use it for 75% of my driving. I am the 4th owner.
CarFax shows "very minor" accident damage from a minor accident in 2023. The truck sustained no damage as the other vehicle bumped the tow hitch. I have pictures of the crash scene.
Don't let the mileage worry you. This trucks looks and drives like new.
I'm not in a rush to sell but am willing to let it go for the right price. CLEAN TEXAS title in hand. . This truck drives like new. No mechanical issues. No CEL.
Asking $25,000 CASH
Early maintenance was done at Classic Toyota of Tyler.
Recent Maintenance records:
2020:
Water pump
T-stat
Toyota long life coolant
Transmission flush
Roof re-painted because the common clear coat issue. My cousin painted it as soon as it started fading. Extra coats of clear was used.
2022 At 168,000 miles:
Replace drive belts
Power steering flush
Brake flush
4x4 service (front/rear/T-case fluids)
Replace coolant
Battery replaced by Toyota of Denton at 170,000 miles
2023:
Regular oil changes
Cabin air filter
Engine air filter
New K02s all around at 180,000 miles
LT265 /75 R16 123R E1 RWL
Warranty certificate should be transferrable to new owner. I still have the receipt.
Balanced/rotated at 190,000 miles on November.
There are some minor things that I don't have receipts for but there have not been any repairs needed. Brakes were done right before I bought it from my cousin. Timing chain sounds to be fine. If you want me to look into something in particular, just ask.
Modifications:
OME HD shocks/springs.
SPC Upper control Arm
3rd Gen Tacoma TRD off road wheels
New K02s all around at 180,000 miles LT265 /75 R16 123R E1 RWL
TJM T17 Front bumper (steel)
New Warn VR EVO 10-S winch (installed September of 2023)
FACTOR 55 Prolink Winch Shackle Mount
LED ditch lights
Pioneer Headunit (old)
Aftermarket JBL speakers in all doors
The bad:
Cracked windshield
Overhead console display stopped working (common issue/ easy fix)
Located in Houston,Tx
Just replaced the entire rear driveshaft with new oem unit. You won’t have to worry about the u joints or carrier bearing for another 200k miles.
The truck currently has 207,000 miles. The driver rear axle seal started to leak so I went ahead and had Fred haas Toyota replace the seals and wheel bearings on both sides.
At 207,000 miles the following was done:
1. Axle seals and wheel bearings replaced on both sides of the rear axle.
2. Both rear brake shoes replaced
3. New brake fluid.
4. Rear diff fluid drained and replaced.
It was very expensive (the rear wheel bearings alone cost almost $650 each) but should be good for another 200k.
At this point it might be best for me to keep it but I will be open to reasonable offers.
How is the frame?
Sorry for the late response with this but I just now got a chance to get under and take some pictures. The only surface rust on this truck is on the leaf springs. The reddish tint you see on bolts, seal sealer and course surfaces is going to be for the reddish tint first we have north of Houston. It stains those surfaces and will really take some elbow grease to get out. If you have something you’re concerned about in particular, I can get some better shots or videos. What looks like thick grease or fluid on the diffs and part of the frame is going to be residual fluid film. The fluid film attracts a lot of dirt.
Status
