2008 GX470 Front Wheel Bearing replacement
I need to replace the PS front wheel bearing on my 2008. I picked up the parts from Toyota yesterday:
bearing assembly with 4 bolts
inner o-ring
outer seal
I've read the FSM on it, but, being a fundamentally lazy person and short on time, am wondering if it can be swapped in without removing the whole hub assembly from the vehicle. I've searched the forum, but haven't found a write up on it (which suggests maybe that it can). Does anyone know?
Thanks,
bill
Nope - You've gotta press the hub out of the old, and into the new...if you just have the bearing.
I bought a 'complete' unit from 'Blue Pit Bearings' to avoid the need for the press. Take a look at their website ( Blue Pit Bearings | 2003-2014 TOYOTA & LEXUS 4X4 and 4X2 COMPLETE FRONT HUB WHEEL BEARING ASSEMBLIES ), there's a pic on the first page that shows the complete unit. Compare to the parts you have, and proceed from there.
Edit: Here's the pic:
^^^ That's what you need to have to bolt it back on, repaired.
- Brian
- Brian
Thanks! yeah, I just have the bearing unit with the 4 bolts. The FSM says to disconnect the steering components and pull the whole spindle off the vehicle. Your pic suggests though that the hub and bearing could be withdrawn together from the spindle. Is that true? I don't mind pulling the hub and bearing together, and pressing it into the new bearing.
Bill
Bill
From what I can remember, yes. Just remove brake caliper and rotor. Make sure the axle nut is fully clear from the axle shaft before you kill the threads on the axle...
And don't forget the bolts when you're pressing in the new bearings LOL.
That's great, thanks! Yes, I keep repeating "don't forget the bolts" in my head :D
Thank everyone for all the input. Just a quick wrap up for anyone searching this subject:
Blue Pit is probably the best way to go. Because of travel plan time pressure I purchased the equivalent parts (for 2008 4Runner) from my local Toyota dealer, including the axle flange, who had them in stock. The extensive disassembly indicated in the FSM is NOT necessary. Simply unbolt caliper and bracket and move to the side (support with something so it doesn't hang by the brake hose). Remove rotor, remove axle nut, and unbolt the 4 bearing bolts and withdraw from spindle. (I had to use a drift to loosen it up.) Remove old o-ring. Slide new unit back on spline with new o-ring, torque the 4 bolts, retorque axle nut (173 flbs) and replace rotor and caliper. Done.
It was a little cheaper buying parts from Toyota ($325, no shipping), but then I had to run out and buy a 12-ton press ($125) to push the axle flange into the bearing. In retrospect I should have bought the press years ago. Would have made lots of nasty jobs I've done a piece of cake.
Blue pit is awesome. I did both front recently and it was worth every penny
Man, I should have you on speed dial. All of my questions it seems you have done to your ride. Along with front brake pads/ rotors I was going to change out the wheel bearings and saw the Blue Pit Bearings. You still recommend them? Also, when you replaced your front brakes did you replace the pads/ rotors and shims. Ive read somewhere that the GX requires replacing the shims but not positive. Thanks.
I did. EBC pads come with stick on shims so they are easy. Helps when I have wheeled and maintained mine for going on 5 years
Sent from my iPhone
I bought them from him a few years back for my Tacoma. Quality parts. Even installed longer studs for me so I could add a 1/4" spacer.
Does anyone happen to know the Koyo part number for front wheel bearing itself?
As much of a PITA it is to press the old hub out, I'd just buy the bluepit option. That's what I did on both my fronts. To swap the whole assembly as received from Bluepit:
Raise front > remove wheel > remove disk and caliper > remove axle nut > remove 4 bolts from hub assembly >remove hub assembly > clean the cavity if you want. Installation is the reverse of removal and the 2nd one I did took me about 25 minutes start to finish.
