2007 LC Fuel Pump
Helipilot
Arkansas
The LC started running rough a couple of months ago. My Longtime technician put on his magic diagnostic tool and determined injectors were now flowing as required. We put in two bottles of Sea Foam and the engine started purring again as usual. About three weeks later the fuel gauge stopped reading a correct fuel level. My thoughts are the Sea Foam dissolved some varnish in the tank and it re-deposited in the fuel pump float mechanism leading to inaccurate readings in the fuel gauge. Checked the price of a new pump and filter and it was over $500, Any ideas, i.e: add more Sea Foam?
New pump will not correct fuel gauge. But if issue on fuel pump hanger (pump, float, sensor, ground, wires). Your mechanic can check their, function while pump out.
Denso, no longer makes any fuel pumps. Any, you get from third party. Is either old stock, if lucky. Or bootleg Chinese junk.
You may find you've rust in fuel tank, which clogs sock and is hard on pump & filter. Is so use magnet and vacuum bottom as needed with hand pump/large syringe.
Advantage of OEM fuel pump in 06-07. They come with sock/pump filter.
The 06-07 fuel, has bad fuel pump. That gives a tell, when failing. Engine will stall, after long acceleration as foot taken off the gas. This is most notable on hot days in summer, when climb mountain passes as we crest the pass and let off the gas. If reading for DTC at the time, before IG key off. We see BK1 & BK2 lean pending or even current.
BTW: Rust/iron deposit in fuel tank. Is from bad gas. Bad gas is from old iron fuel storage tanks at filling stations. Newer filling stations, will have composite storage tanks, so good gas. Most states also have inspectors, which list data online about each filling station. Which includes if they replaced the storage tank.
One sign of rust in tank. Is lean fuel trims. Which can also be weak pump, weak voltage to pump, weak fuel pressure regulator, vacuum leak.
Other things may be going on with engine also. Tune, coolant service, wonky MAF. Even a compression test may be warranted. Especially if intake air has not been property filter, overheating and or S.A.I. filter missing.
