2006 Sequoia Transmission Issue - Vibrations in Low Gear at Low Speed.
VA
Hi All - we have a 2006 Toyota Sequoia Limited (4.7 V8 with 230K miles). All in all, the truck is clean, no rust, maintenance up to date and runs smooth.
That said, we've noticed it began to have a shuttering vibration in low gear - I believe shifting between 1st and 2nd. Once you ease off the throttle and apply gas, it goes away. The vehicle has no issues at speed however the vibration only occurs from idel off of stop lights and when you're accelerating below 25 mph. This was worse before but after flushing the transmission fluid 3 times, the problem started occurring less and less however, it still remains.
Has anyone else encountered this issue before on this model?
If so, what has been your solution? And cost for your the repair / parts?
Thanks All!
Yes, those were looked at initially and greased as a solution but, the shuttering remains.
