2006 LC Jumping Timing
San Diego, CA
Hello all - thank you in advance for your thoughts on this issue.
I have a 2006 Land Cruiser (3rd owner) - currently 140,000 miles - that has good maintenance history and is rust free (always a Southern California vehicle).
The timing belt / water pump / thermostat were changed just prior to my ownership by the listing dealer at 115,000 miles. I have the invoice for this work.
Recently, I had an oil change performed by the mechanic whom has worked on my vehicles for the past 3 years. He's been great and always straightforward, going the extra mile to diagnose issues and get things repaired quickly.
I picked up the cruiser Tuesday afternoon and brought it back to work - no issues, ran great. Left work Tuesday evening and the check engine, VSC OFF and VSC TRAC lights were all on (solid light - no flashing). I've run into this in the past and its come up as a CAT code - after clearing it never returned...this is what I expected it to be.
Left for work Wednesday morning with the warning lights all still on. Reach the on ramp to the highway and found there to be limited power when pressing on the accelerator with a slight shudder under throttle. I maintained speed and decided to continue to my mechanic and see what he thought.
I received a text several hours later that all signs pointed to the timing belt jumping a tooth. He confirmed today (Thursday) that it did indeed jump a tooth.
My question: Is this common? I've searched and found limited information. How does something like this happen?
Since taking ownership, I've religious saw to it that maintenance was current with extra preventative maintenance being performed. Complete blank checkbook with said mechanic to insure everything that should be taken care of was in due order.
Again - thank you in advance for any and all thoughts!!
Toyota 4.7 will actually run mostly OK off by a single tooth. There really isn't any way for that to happen, and the TB tensioners have way more than 140K miles of life in them, even if it was original. I really, really doubt the TB is off a tooth. If it is, it was likely put on that way (you can actually do that if you put the belt on backwards and try to time it that way).
You've got another problem, for sure, at least as much as you have a mechanic who has you convinced your truck's TB is off a tooth.
My $$ money bet is on your fuel pump or a bad injector. You can get cat issues with those.
It doesn't seem very likely that it jumped a tooth. But get him to reset the belt, and check the pulleys and the tensioner. The factory service manual has a procedure for checking the pressure on the tensioner piston. That either does or doesn't fix the problem - pretty straightforward.
I'm not saying it can't happen but it is highly unlikely. it is a 1"+ wide cogged belt, and wraps around the crank and both cam shafts close to 180 degrees, having done 2 timing belts on 100 series engines, I don't see how it can happen.
If it did happen all of a sudden, then why? why did it only go 1 tooth? it doesn't make cense to me.
