Hi guys
I was able to fix my LX470 2004 gauge cluster.
So the issue was that on start up needles were shaking with some noises behind dash and after couple seconds they came alive. Except tach and couple other random ones. But tach needle was always dead.
The issue with my particular gauge cluster were stepper motors. If you dissasemble the motor, you will notice that there is circlular magnet with plastic sleeve inside. Because of the aging sleeve starts to slip inside the magnet. Once I superglued sleeve to the magnet, my tach came back alive.
Alternatively you CAN use those stepper motors from
amazon, but you would need to move upper cover with springs (carefully) to the new motor, bought from
amazon. There are only 3 clips holding stepper motor cover, so it was not a big deal. Just don't rush and take your time.
Assembling stepper motor is tricky due to the way gears positioned, but my solution was to put the motor cover with needle gear and middle gear on the table, and then once I aligned shafts with opening with motor shafts, clip it all back together (my wife's idea). Ensure to align gears properly as per sketch below and after assembly rotate the motor by the disk where the lighting spring is attached to, and compare it other motors. Force and rotational range should be identical.
Additionally, you don't need to fully unsolder the motor from the board to glue the magnet. Full unsoldering required only if you decide to replace the motor.
The motor cover is being held in place by those 4 soldering points and plactic clips on sides. I unsoldered those 4 points, got a thick angled needle and unclipped stepper motor cover to glue the sleeve to the magnet.
After assembly check coil continuity with multimeter to ensure that you did not damage coils (I check with measuring resistance, should around 235 or so) via points circled red.
And now I am enjoying working tachometer.
