2003 Sequoia Ignition Key Ring Light and Firewall access
Los Angeles
Good day! Does anyone here know if a 2003 Sequoia is supposed to have a light around the ignition key ring? I saw a Youtube video how to replace the ignition key light bulb for a 2007. If the answer is no for the 2003, can the ignition key cylinders be swapped across year models?
Second Q is can someone recommend a good way to pull wires through the firewall of a 2003 Sequoia? I tried looking for grommets and can't seem to find one. I'm sure there has to be since at minimum all vehicles have wires and the steering wheel coming through the firewall.
Thanks all!
Yes! The 2003 Sequoia does have a light around the ignition key ring! I replaced mine with an LED T5 bulb and am happy - not only is it functional, it also looks beautiful! A very worthwhile project to do. Takes 15-20 minutes.
Toyota Sequoia\Tundra Ignition switch ring LED light - YouTube
