Yes, but they are out of the HID business. Probably easiest to buy a new relay kit.
They are? Their site still has everything HID related still on it.
, it's about as good as it will get with a stock halogen housing. I am starting to have this same issue with mine. I also have the 55 watt DDMs. At first it was just one side, and I thought something was wrong with it. But now it has been both sides. If I turn them off and back on they usually fire up on the second time. I ordered the DDM wiring harness with my kits originally, but did not put it on yet. Going to install it now and see if it makes a difference, because it seems like they are just not getting enough power to start them both up.
I also have 35 watt for my fogs.....and have had no issues with them. Again pointing me back to the 55 watts not having enough power for the draw at start up.
change the fuse to a 30a(replace your 25a), solved my problems! Does not make sense as to why it did, but it works
Are you talking about the fuse in the relay harness?
LJ - You may have had a bad fuse, but it is not wise to upsize the fuse. I would just go with a new 25Amp. You may burn your wiring, if it is not 10 gauge (rated for 30A).
One more thing that I wanted to post was more detail to my mounting location. I used the brackets from DDM and zip tied my ballasts to them, both vertically and horizontally, and then drilled and mounted the brackets to the front corners of the engine compartment. See the photo of the passenger side. I tried to get one of the driver's side, but the battery was in the way.
Well I finally got around to ordering a set of these today. I wanted the 55w kit though with the slim ballast and the website only gives me the option for 35w. I have tried calling twice and keep getting a voicemail(I did leave a message a few hours ago). I was also going to order some of the led bulbs for the dome's also but I'm hesistant to order anything off of their website until I speak to someone. Anybody order from them recently and have the same experience?
I recently ordered mine. Did all of my ordering from the website, but did follow up when my wiring harness did not come in with the rest of the stuff. I did get their voice mail once and ended up calling them back. The second time I got a live person who was extremely helpful. My harness was on back order and they shipped the same day I called.
I would recommend calling them back.
)I originally put in a 35W DDM kit in the headlights with harness and then added a 35W DDM kit to the fogs.
At first I was impressed with the increased light output but I had a couple ballasts go bad (would flicker or not start, etc.), they interfered with my radio reception and got tired of chasing issues. I was on the verge of ripping it all out and then as a last shot I replaced the DDM ballasts in the headlights with a couple of used Matsu****a OEM ballasts.
You need to get some adapters to use the ballasts with the DDM bulbs and harness but the first thing I noticed was they fire up almost immediately, they are apparently potted and you can add a little liquid electrical tape to the connectors for extra water resistance. Also, they didn't interfere with my radio reception. I managed to find a second set and then replaced the fog ballasts also.
To date I've been much happier using the Matsu****a ballasts. They are OEM and made in Japan and so far have proved much more reliable. You can get adapters on e-bay but I've noticed that the prices of the ballasts themselves vary widely from $50 each to over $200. I ended up paying under $100 a pair for mine.
