Media 200 series picture thread
Photo/Video/Audio threads
Beautiful spot, elkaholic!
Desert Nomad, are those fog light inserts on the bulbar a factory thing or are they homemade? I've been wondering about doing similar with steel ones on my ARB. That way I can mount tabs on them and fit decent LED driving lights behind, and they don't get smashed like the plastic ARB ones every time I hit a six while playing roo cricket
Steel blanking plate in place of the fog light assembly that was falling to pieces and the fog is a morimoto led off of "the retrofit source" with a blanking plate you have limitless options on what to mount for lights only problem is setting up brackets to get the lights aligned properly.
Before and after front strut spacer. Taken from the same location for reference. Very subtle difference.
Before
After
It's like a clear and cloudy difference!
Thanks.
I am a big fan of the fender flairs myself.
That one came with them, same as my 2010 did as well. They appear on the window sticker, but I am told they are Toyota port installed accessory items.
You can still order them from toyota for the 08-11 models, they come prepainted and appear to install right over your factory mudflaps.
Got a bath
full
Sweet rigs..
Love the LC200 fender flares - where did you source them ?
They look exactly the same as the bushwacker flares I had on previously. Those might be easier to source. Just make sure to protect the paint where the lip of the flare makes contact with the fender as it rubbed off the paint on mine
Thanks.
Interesting. I wonder if anyone has the Toyota part # for these flares to order. They are not common at all in the Middle Eastern market - I haven't seen at least on one for the longest of time. @DesertNomad : Bushwhacker ones are Rubbermaid?
I think they are differnt from the bushwhacker flair. The shape is slightly different, and the Toyota flare is gasketed to protect the paint. I could be wrong I seen adds for the bushwhacker that look the same but seen some on an LC that look a little diferent then mine.
I am told Toyota flares are sold prepainted. I have a set ordered for my other 11 that didn't come with them. They should be here in a few days. I should be able to get you some part numbers for a set in Super white. Will post the numbers ASAP.
I notice you show a 12 in your signature, which I think is a 13-15 style LC in the stares, sine the U.S. Spec skipped 2012 model year. These and the Bushwackers show only for 08-11 model LCs.
There is a Black LC with black steel wheels, that has a set cut and modified and for a 13+ LC
One area of issue is the door molding conflicting with the flair.
They have a hard plastic feel http://www.bushwacker.com/fender-flares/toyota-oe-style-fender-flare-set-4-30913-02#product-detail
That was me, the side moulding is in the way of the door trim piece as well as we get the LX style side steps moulded with the rocker panel
MmKB5VZ8OiRHegJkfKiB47f8gR5CrY0LxqbYKuegrPM,Uf2S3fwIquc-3Bf5SeTnT842uQbVbpFNWms7nQLmVhQ.webp
Thanks cc1999 ... Share the Toyota parts # and pictures when you get yours. I'll see if they can be sourced locally.
They arrived today.
Here is the part number
I will take some more pics later when I get them unboxed at home.
Decided to go ahead and open the carton and check and make sure they look right.
Looks right, super white with gasket to protect the paint.
nothing like a box of goodies to make a monday a notch better!
Try calling in that part number, to your local Toyota dealer's parts department. I would imagine they could track it down for you.
If you need it I am sure they would ship out of the US or not. But I can get the name of the dealer off the shipping label. My local body shop down the street order in this set for me.
I tried to google that part number as well, and it appears there is not an easy online source for it.
Well that said you can maybe email one of the online Toyota parts stores that part number they may also be able to track it down for you.
I am sure in todays electronic world, that if you really want a set, there is likely going to be some way for you to get them no matter where you are located. Just might cost a lot and take a while.
I am sure my local body shop used the VIN off my LC that came with them, to track down that part number.
