Taco2Cruiser
Crazy American Off Road
No. You need to remove the silver handle covers and the full panel behind the door release. You’ll find 3 hex bolts that need to be removed. For front door only, pop off the full panel that sits on the back side of the side view mirrors. Then you can pop the panel off from the bottom. Once all the clips are popped, lift the panel strait up, parallel with the door frame. There are the typical C-channel design in the panel that hooks onto the top of the door frame. The. Once you lift the panel off the frame, unplug the window switch and courtesy lift plugs. And finally, I clip the door release cables from their retainer, and rotate the cable out of the fitting on the back of the door release handle.These just pull straight off, correct? I plan to tackle this at some point. Mine is only a 2015, but the wear on these pieces make the interior worn like a much older truck.
