I have run a FT-2400, FT 2600 and now have a FT-2900 it's awesome radio. I just moved my antenna to the rear hatch and it works great. It is the prefect trail radio IMHO.
Dynosoar
Dynosoar
In practice I never talk that much, most of the time it's three or four of us on simplex with the normal flow of conversation no one person talks long enough to cause heat problems.
You've never been on a trip with James aka Redline have you?!![]()
is it common for mobile ham radios to require 13+ volts before they will power on (apparently the yaseu unit requires this? So the engine has to be running for the radio to work.
Yes; they require enough amerage to run at high power that they typically want full voltage. But the engine does not have to be on, if you have a good enough battery. I have Odyssey (or the Sears Platinum Die-hard equivalent) batteries in both of my 4WD trucks, and both will run a ham radio for a long time without the engine running.
... I assume the radio is very picky about 13+ volts.
I'm running 10 ga wire from the drivers side battery all the way to the radio. The radio is mounted on the console between the front seats.
...I assume its on low power and I just turned it on to make sure it works.
After looking at the pdf manuals for the two radios I initially referenced...I would say Yaseu needs to go back to school and Icom seems to do a fairly good job on their literature. I own the Yaseu so I'm still in process on reading and understanding the manual I have.
12V sounds low for a fully charged automotive battery, it should be around 13.5 to 14V. Try putting it on a charger overnight and measuring the voltage with the battery out of the truck.I have a dual battery setup, gold top autozone battery which is a good battery. No matter how good the battery is with the engine off you only get 12 volts. I'll check the battery but my assumption is that it is good. I assume the radio is very picky about 13+ volts.
Im totally green with the radio...I assume its on low power and I just turned it on to make sure it works. After looking at the pdf manuals for the two radios I initially referenced...I would say Yaseu needs to go back to school and Icom seems to do a fairly good job on their literature. I own the Yaseu so I'm still in process on reading and understanding the manual I have.
If it is one of the continuous duty relays commonly used for powering trailer connections they rarely go bad. To check it apply 12V to the coil and measure the contact resistance, it should be very low ie <1Ω.Ok another follow up..
12.6 V on passenger side battery (main battery)
11.6 V on driver side battery (secondary battery) radio wired to this battery.
Ok I think I've found the issue... #2 battery is not in good shape.
Right now I just have a small isolator relay that controls the 2nd battery...looks like its a piece of junk or maybe the battery is bad.
Appreciate the feedback...I thought / assumed both batteries were good...and they were not.
