2.5" Shackles
Tulsa, OK
Are 2.5" Shackles going to make an FJ40 2.5" taller than stock or are they only 1.25" taller than stock?
my64fj40 said:
They are only lifting the springs on one side so they only lift the cruiser 1.25"
And probably less than that actually, because the shackle is on the long side of the spring.
Ed
As discussed before in other threads regarding this question, when you add shackles that are longer than stock, you stress your springs and get less than half of the lift that you're adding in shackle length over stock.
So, a 2.5" longer shackle will generally yield about 1" - 1.25" lift, will shorten your spring life a fair bit, and sometimes create a harsher ride since the shackle angle gets closer to vertical...
IMHO, it's best not to add more than about 1" over stock, and that's just to improve articulation. If you want lift, think about some new springs, an add-a-leaf (has its own evils), or some larger tires.
~John
Does anyone have an opinion regarding longer shackles?
Maybe I need another cup of coffee, but I'm just not seeing how they would shorten spring life...
more leverage on them due to them being longer? don't let teh springs arc through their full range of movement? dunno
probably does no harm that the stock ones wouldnt do.
2.5 inch
I just put 2.5 inch lift shackles on my stock 40. The shackle itself was 5 inches eye to eye. I thought it was way too tall, after I muscled them into place the result was perfect. With the hard top on , the rear end is just slightly higher than level. It looks great. I can send pics later. They were universal H-shackles I bought at a 4X4 place for $52.00, The bushings were $45.00 for all the spring points. I re-bushed all the spring and frame attach points. THe springs were original (32 years old) they seem to be holding up fine.
So Colorado Boy did you measure the truck height before and after? How much did it lift your truck?
About 2.5 inches
It was approx 1.5 inches below level at the rear wheel well, now it is about 1 inch above. Pretty conservative looking. I didn't want it all jacked up in back . I thought it would look goofy.
pics
shackles
more pics
The first pics show the old versus the new shackle, I guess the eye to eye measurement is closer to 5 1/2inches. these pics show the after ride height.
