no water pump while you're there ..?
Nope, I've not had to change one on any of mine with 2-300k km on the original pump.
I'm not saying don't change it, but I don't think I would.
I would look for signs that the water pump has been leaking. There is usually an accumulation of dried coolant in the drain hole under the pump. Ive replaced a few, they all went around 250-270k/klms
with the work involved in the water pump replacement and the price of a new water pump .. I would replace while there no question ask ..
my .0002 cents ..
What are the prices for a pump in the US, I think last the time I looked it was about $150USD for me delivered from Saudi Arabia? It would be a pity to throw away a good pump. If the engine has truly dome 100000klms, the pump should be good for at least another 150000klms.
His call.
looking for a bit of info here. its time to do my BEBs and i’ve never done this before. i ordered up the parts from 4wheel in edmonton. to turn the engine over does one need to pull the glow plugs or anything or it is it possible just by hand. i recently did my timing belt and seem to remember that i could turn the crank without decompressing the cylinder but just trying to move a piston a little to change the bearing might be different!
hope i’m not too late to my party changing them out. engine runs great but i’ve noticed a new rattle sound and it seems to be coming from the lower back area of my engine. they’ve not been done as far as i know but i’ve been preoccupied with other maintenance. cross fingers it’s not a sign of a needed rebuild now!!
There's a real risk of damaging crank journals changing BEBs with the engine in the car.
IMO, is best to do some oil sample analysis first over a few oil changes, and look for signs of bearing degradation first.
Where do you see the risk?
Have been doing it a few times, not a big or risky job in my book?
But to change the entire crank because of PO not checking up on the bearings _that_ was a big job...![]()
Main risk I see is accidental damage to crank journals.
Rotate the crank with a rod in a bad spot, rod bolts can certainly damage a journal.
The idea that BEBs HAVE TO be changed every 100k km is garbage.
Countless 25yr old 1HD-T running around on original BEBs with 5, 6, 700 k km on them.
Oil analysis will give you an early warning. If you change oil every 5k km, analyse every 2nd oil change.
The BEBs aren't going to go from pristine, to hand grenade in a 10k km interval.
