Just plain stubborn. Then I tore up one of them. Need to find some new ones. Heat, PB Blaster and patience are always the key!
Sounds good! happy to take photos or poke around if anything would help yaI'm not sure you could easily measure the difference, the photos make it look very slight....I think the difference between alternator mounting points is only 5mm which would be hard to measure on vehicle.
However, your info is helpful: I believe your rig came with a 60 or 80A and it lists the smaller-arc bracket, P/N 16381-17010. The bigger arc bracket for the larger alternators, 16381-17020, is listed on some other 1HZ models that came with a larger 100A+ alternator. That said, you are confirming the conclusion I drew from the photo above: The FJZ alternator requires the smaller-arc bracket (or minor modification of the bigger-arc bracket). I'm pretty sure I have the larger-arc bracket as the 27060-17250TT alternator I have installed was used a on vehicle that also lists the larger -20 bracket.
I'm aware of that alternator, but I don't understand the use case/problem being solved. Maybe if I had LTO batteries that could fully charge in 15 minutes, or wanted to weld from my truck regularly? Otherwise that money seems better spent on shocks or something that palpably improves the user experience.
