1fz mpg
Before I added any mods to my 80, I rolled into a gas station with about 406 miles on the tank. That's a hair over 16 MPG on a full 25 gallons and I truly used it all, as it died as I was still rolling to the pump.
Now, I typically get 12.5 MPG as a DD with 14 miles each way, minimum. This equals 312.5 miles per tank. (See sig line for mods)
I changed my tank, but used the same pump and sender. Prior to the change, I always had exactly 5.0 gallons left when the light came on. Now I have about 3 gallons left when the light comes on.
These tanks hold exactly 25 gallons when you click the pump like 10 times getting as much in as you can.
You make more friends with pictures. Your new friends will graciously show you how to spend money on your new bad investment.
Welcome! You're gonna love it here.
Not much yet
Looks to be in good shape from the he pictures. What are the little tabs on the edge of the hood for?
Also you have paint fading on the roof you might consider monstaling it if you aren't in to painting. If you spend time in the heat a lot i recommend a light color or white.
For me, when the warning light comes on, I have about 4-5 gallons left in the tank.
Four to five gallons remaining seems to be the norm for most 80 owners when the warning light comes on, but a word of warning, you should check your truck to be sure. I checked my truck twice, and both times my light came on when i only had 3 gallons left. So as i said before, it's best to check your truck before you find out the hard way you only had 3 gallons left, instead of 4 or 5.
I actually have no idea what the little rubber bumpers on the hood are. Do they not all have those? Lol
No but someone is now freaking out trying to find a part number so they can have whatever OEM part added to their ride now. Probably just makes it go faster.
Those are bumpers from a particular brand of bug shield/air dam that used to be on the truck.
Not factory.
So I just had my top end rebuilt from a blown head gasket and I'm getting about 280 to 290 before the gas light pops off.
But my speedometer is showing slower than actual speeds by almost 10 percent. I have 285 17 70 Duratracs. Does that mean my mpg is a bit better?
'80s have a 24 gallon tank. The warning light comes on at 4 gallons left. There may be slight variance in this, but every one I have had reason to deal with this on has been consistent. (I currently own 5 FZJ80s that all get driven enough to verify this too). My primary rig gets between 15 and 17 mpg on the highway when driven gently on 315s. The recent switch to 4.88s does not seem to have adversely affected this. This fuel use has been verified repeatedly by carefully measuring exactly how much fuel is required to completely fill the tank by hand from containers and completely refilling it after measured distances. I started doing this after realizing that the data from my OBDII was inaccurate. Three of the other rigs are driven enough to contribute data points too. They all average around 15, on 275s and 285s, occasionally doing better. The fifth rig, with about 500,000 miles on her was getting 12-15 on the highway (on 315s) before she rolled into the shop for rehab. At least 3 friends with '80s are getting 15-16 on 315s.
Trying to get a grip on your fuel use by asking about miles per tank is pointless. Especially when you don't know how big the tank is or really even how much was left in it, or how close to completely full you got in it. And if you are not correcting for speedo/odo error after doing a regear (or even checking for accuracy in a rig with OEM gearing) then you are really just tossing out meaningless numbers.
Mark...
At 200 miles I start looking for a gas station. At 230-240 miles I won't pass by a gas station no matter the price. I've only had the gas light come on a few times in the last 4 years using this method.
On my recent 2500 mile road trip spot checks were in the 13.5mpg range (with RTT, 33"'s, stock otherwise).
I usually get around 280 miles per tank with old man driving in an area with no stop and go traffic but lots of rural and hilly roads. I don't usually let it get below a 1/4 tank though as gas sales can be spotty up here. Plus, given that it's hard to find regular gas anymore, I prefer to get as much new corn gas in as often as I can because I don't trust that stuff and I don't drive my 80 every day for long distances.
Yes, you actual mileage traveled is more than what your odometer shows, so you are getting about 5% better mileage than what your numbers are telling you.
Woo hoo! That calculation means that I average 14.07 MPG! That does seem pretty close to right though. I guess I am close enough to the original MPG estimate that I am fine with mine.
