Parting Out 1999 Toyota Land Cruiser
Still interested in these if you have them.....
Disregard as I have found knobs locally. I would advise that you give fellow MUD members the courtesy of a response in the future......
Are the nuts/screws that attach to the rear window vents still available? Also, what is the condition of the inside rearview mirror and steering wheel?
You said the hood is straight? Do you still have this?
Rear window wiper blade? Possibly also the wiring for this?
Does it have a sunroof? Looking for a sunroof motor assembly, the electronics on mine are shot.
Also, any of the skidplates underneath available? How clean is the undercarriage? Looking for the cross member that goes across the middle of the frame.
Rear mudflaps make it out alive?
Looking for armrest/door pull off either driver-side door (they unscrew from the panel). Don't need the panel. zip code 32828, if you have it. Thanks!
ront lower control arm nuts? I'm missing one for the front passenger side for the forward lower control arm nut.
I need the EFI relay which is inside the engine compartment fuse box sent to 21710 in Maryland
