Work in progress...but good progress for a someone with a very busy day job
-rubbed out a lot of the paint and there is a shine coming thru. Will focus on that later. The driver door is rusty because it was replaced after a deer collided with the side and the body shop did a terrible paint job on the new door.
-Radiator ended up being very nice so did not need to clean or change. That Toyota red is definitely super long lasting. Cleaned out cooler line on radiator where a pretty good size glob of gray stuff came out...seems common from reading here.
-Put on new hoses
-Replaced both idler pulleys
-Replaced the 3 belts
-front crank seal replaced - had to buy a few hundred in tools including OTRAMM crank bolt tool, harbor freight torque wrench 30mm socket, etc. a real involved process but cool to see how it all works.
-oil pump seal done
-oil and oil filter done
-plugs, wires, cap and rotor done
-gas tank out and back from cleaning and linIng. Have new straps to put in. New fuel pump cluster is assembled and waiting to go back in.
-fuel filter out and line to tank cleaned - working on that today with hopes of getting all lines cleaned and gas tank back in along with fuel filter.
-hoping the fuel system north of the fuel filter is working- not looking forward to fuel injectors but will do it if needed...
- brakes need help so that’s next.
